Master Cylinder
Old Dec 7, 2004 | 12:44 PM
Master Cylinder
I like this Dodge master cylinder (87 3/4 ton van), but I think the bore diameter (1 1/8") is too big for manual brakes
Does anyone know what application matches that but has a 1" bore diameter?
Old Dec 7, 2004 | 03:01 PM
What are you making JZ a hybred Mustang?
:P
Old Dec 7, 2004 | 03:06 PM
I'm kind of stuck between a rock and a hard place, I'm using 73mm piston calipers up front, which generally require more volume, however with out the power assist I'll have too hard of a brake pedal with the larger diameter bore size.
I have to measure my pedal ratio. I have the factory manual brake pedal. If the ratio is around 6:1 I can use the 1 1/8" diameter bore, but I think I'm only at 5:1.
Good info here:
http://www.mpbrakes.com/manual.htm
It's a real kick that some of these aftermarket brake companys would sell me that same master cylinder for $139 when if you know what your looking for it can be had for $22
Old Dec 7, 2004 | 03:15 PM
:P
Oh ya, mix and match all the best parts!!
You Mopar guys sure do have a nice master cylinder there, and it bolts right onto our Fords
18
May 27, 2005 06:32 AM
10
Apr 14, 2005 10:09 PM
Parts for Sale
Dec 23, 2004 10:35 AM
82GT
17
Dec 7, 2004 01:36 AM
6
Nov 23, 2004 03:13 PM
