Wire size for high output alternator?
Old Jan 11, 2005 | 02:12 PM
I'm using 1/0 welding cable from
http://www.weldingsupply.com/cgi-bin...F:OR:terms::PA
I bought the swedge on tool for the cable lugs, should come out nice once I get to it.
Old Jan 11, 2005 | 02:20 PM
Duh, your talking about the atl wire, my bad (lack of sleep).
Do you have to run it through the disconnect switch to power off the car?
Old Jan 11, 2005 | 02:22 PM
Originally Posted by mikelbeck
Is that cable flexible?
It's way more flexible then the 1 ga cable that came with the Moroso battery relocation kit.
Old Jan 11, 2005 | 02:35 PM
The chart for the welding cable only goes down to 4ga which is good for 100 amps up to 100'
Old Jan 11, 2005 | 03:04 PM
Welding Cable By The Foot
Industry standard class K neoprene insulated welding cable. Made from 30-gauge soft-drawn copper strands for superior flexibility. Properties: 600v, -40 deg C. to +90 deg C., heavy duty/all purpose.
Old Jan 12, 2005 | 12:05 PM
bdyj's Avatar
I used an 8 gauge wire to my battery in the trunk and have not had a problem in 4 years. I run an 75 amp one wire.
You have to connect the alternator to the battery side of the switch or directly to the positive side of the battery.
If not the car will not shut down if the switch is turned off.
Old Jan 12, 2005 | 04:23 PM
Mike, what you could do is (if you already have 1 8ga wire) is to run a second 8ga. New math; 8+8=4ga equivalent. On long runs, the bigger gauge the better. If the wire heats up, you loose efficency.
Old Jan 17, 2005 | 12:26 AM
Smink's Avatar
I've got a Delco 3-wire 100 amp with internal regulator.
Direct wire to the positive post in the trunk is TEN GAUGE.
Do some checking, 10 gauge is all you need.
Old Jan 17, 2005 | 08:20 AM
BBLM23's Avatar
I have cooked several 10 gauge wires with my Chrysler alternator. I switched to 8....
Old Feb 11, 2005 | 07:18 PM
Looks like a good deal. It's got lots of strands. That 'il git 'er dunn.
proe305
4
Jul 12, 2006 11:02 AM
4
Apr 24, 2005 04:46 PM
Parts for Sale
Apr 13, 2005 12:52 PM
15
Nov 3, 2004 12:50 PM
sickt7cuda
Engine/Chassis/Race Car Builders
12
Aug 4, 2004 09:44 AM
