Line Lock Problems
Old May 14, 2005 | 06:06 PM
It should be mounted up and down. I would think it spit when you stepped on the peddle and suck when you release.
Where is it sucking air from. Maybe you have a bad brake line or brake line connection.
I know they are rebuildable but for the price I would replace it if its the
unit itself.
Old May 14, 2005 | 07:35 PM
Like Tony said, it should be mounted upright with the brake lines out the sides. I've never tried to take one apart, but I'm sure it's a simple restricted orifice that, in your case, is most likely the victum of some dirt or debris. Try disconnecting the brake line, blow some hi pressure air through it backwards.
Old May 15, 2005 | 02:04 PM
I cant get mine to hold. Brakes are bled, Adjusted the front brakes but Its not holding.
Old May 15, 2005 | 04:00 PM
Are you sure its not holding or are you pushing through them.
Roll through a little water pump them hit the button and then try it.
Old May 15, 2005 | 04:51 PM
Its possable Im just pushing threw it. Maybe to much tire, not enough gear. I'm going to start the transmission/gear swap this week.
Old May 15, 2005 | 09:39 PM
I have a hurst in my car but there over $100 now. I just buy another Biondo. I hear there good.
Old Jun 3, 2005 | 04:40 PM
1BadMirada's Avatar
hi..i had the B&M linelock on the mirada..and i hated it...it was slow to disengage...and after pushing my skinnies the first 25 or 30 feet a few times, i took it off, and havent looked back. in the CC national circuit, it seems that LOTS of guys in sportsman run them, but i cant figure out why.
Jul 16, 2006 04:00 AM
Apr 2, 2006 04:00 AM
18
May 27, 2005 06:32 AM
10
Apr 14, 2005 10:09 PM
82GT
4
Dec 7, 2004 03:15 PM
