Raceology - Science of Auto Racing RSS News Feed from Raceology.com
Quantity Has a Quality All Its Own
Old Jul 27, 2005 | 12:00 AM
News Feed's Avatar
<span style="font-weight: bold;">"Quantity Has a Quality All Its Own"</span>
By Don Terrill (c)2005
Stalin was referring to Russian Tank production during WWII when he said "Quantity has a quality all its own." This may be tough, but let's consider the quote, and not the man it came from.
In the past, I'm not sure if people ever meant it when they said "Bigger is always better", but today it's used to make fun of those who always want more - be it compression, camshaft duration or carburetion.
The new cliche is "Bigger is NOT always better" - a phrase I hear way too often.
The fact is though, there are areas in racing where just plain bludgeoning it with more works.
<span style="font-weight: bold;">More outweighs better:</span>
<ul>[*]
<span style="font-weight: bold;">Engine size -</span> If there are no traction problems, more engine will always equal more performance.[*]
<span style="font-weight: bold;">Power-Adders -</span> Let's face it, the worst Nitrous system can still make a ton of power; and more Nitrous is going to make more power. The same goes for the boost from a turbo or blower.
<span style="font-weight: bold;">RPM -</span> This formula says it all; <span class="postbody"> Horsepower = (Torque X RPM) / 5252. As you can see, anytime you can increase RPM without a corresponding loss in Torque, you are going to make more power. The key is getting enough air into the engine.
</span>[*]
<span style="font-weight: bold;">Money -</span> This is an easy one; it doesn't matter where it comes from, it all spends the same; and more is better.
[/list]On the flip side...
<span style="font-weight: bold;">Better outweighs more:</span>
<ul>[*]
<span style="font-weight: bold;">Engine Builders -</span> There are a 1,000 ways to make (x) amount of horsepower, choose only one. Start mixing the ideas of more than one engine builder and you're finished.[*]
<span style="font-weight: bold;">Crew Chiefs -</span> One great crew chief will beat five good ones every time.[/list]I got this blog post idea from watching too much of the History Channel. An example of more is better? I'll let you decide.
Think I'm out to lunch? Fine, write your own article
Read more...
Source: Raceology - Science of Auto Racing
Technical Column by Don Terrill
Feb 14, 2006 08:00 PM
Feb 13, 2006 04:00 PM
Aug 8, 2005 12:00 AM
Aug 1, 2005 04:00 PM
May 9, 2005 10:48 AM
